Trans leak
  • Rayprato
    • Oct 2013
    • 21
    Trans leak
    Just finished a spec e30 build. Had it on track 2 weeks ago. Only issue was a moderate leak coming from the bottom of the bell housing. I pulled the Trans and saw that the inside of the bell housing was soaked. The clutch and flywheel were bone dry as was the engine behind the flywheel. I replaced the input shaft seal and used black RTV Silicone on the seal flange and bolts. Put everything back together and took it for a ride around my block. After around 6-8 miles I checked it and it was dry. It sat for a week. I just went around the block once more and put it on the trailer to get it inspected today. While on the trailer I noticed a drip. Obviously I didn't fix the leak. Any ideas would be much appreciated. Btw, the top of the transmission was bone dry around the breather. I'm lost and have a race weekend this weekend. Thanks
    Ray
    Raypratojr@gmail.com
  • Poorboyz
    • May 2012
    • 2117
    Maybe the clutch slave is leaking into the bellhousing? Check the brake reservoir.
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
