Ca-thunk
  • BenDem
    • Mar 2014
    • 75
    Ca-thunk
    Hi all.
    So, I just picked up my first e30. (Actually my first car in about 15 years).
    325i with an auto (non-electronic). It drives very well, shifts smoothly through all the gears, up and down except -- when coming to stop when the trans shifts from 2nd to 1st. A pronounced thunk.
    If I ever so lightly keep the revs up (like 1k), while braking to a stop -- no thunk.
    Trans fluid is clean and does not smell burny. I was planning on starting with checking the transmission accelerator pedal, but anything else I should be looking at? Could something in the diff or driveshaft be causing the symptom?
  • Chillin_30
    • Jan 2013
    • 16
    Check Diff Fluid
    • BenDem
      • Mar 2014
      • 75
      Originally posted by Chillin_30
      Check Diff Fluid
      OK. I'll just flush and fill as I don't know when it was last changed anyway.
      • BenDem
        • Mar 2014
        • 75
        New diff fluid hasn't changed a thing.
        The PPI I had done reported that all the bushing, u-joints, etc checked out fine. I'm going to take a closer look, aside from the u-joint, anything else I should pay particular attention to?
