Gonna make this nice and simple, I have an AASCO M52 Flywheel with a spec stage 2+ clutch, everything installed nice and easy. I fired up the car and pressed the clutch in a bit quick, it was smooth to start and then the pedal started to shake back like the clutch was moving back and forth a bit. I was a bit concerned and let off of the clutch until right before it stopped vibrating and put it in gear no problem, and started letting off and the car started rolling and the clutch was engaging,
Is this as simple as the slave cylinder pushing the pressure plate past what it would like to be?
Thanks!
Thanks!
