I have a 84 325E early model with no guibo. How the heck do you get to the front bolts? I have the rear drive shaft mount and CSB off. I am needing to change the CSB as it is totally gone. Started to remove the transmission support to give a few more inches of access. The drivers side aft bolt seems to be spinning. Is there a small clip that holds the bolt in place from inside the car, maybe under the seat? Is it replaceable?
HELP!
HELP!
