Late Model (7/89 build) which driveshaft
  • adjmcloon
    • Apr 2012
    • 446
    I need to replace the driveshaft in my '90 325is (manual)
    Pelican says there are 2 possible drive shafts, one is threaded and one is not. Is there any way to tell which one I need without dropping the driveshaft out?
    • 37833
    Any 5 speed M20 driveshaft will work as long as it's not the rare 87 large guibo version.
    If you use an 87 and earlier shaft you'll need to swap to a late model CSB.
    Grover Beach, California
    BimmerHeads.com
