m30 swap 265 leaks
  • Red88
    • Nov 2008
    • 1161
    m30 swap 265 leaks
    hey guys... I have an m30 swap and I'm using the transmission with the removable bellhousing. The bitch leaks though out of the seals between the cases. Does BMW sell these seals? I can't find them on realoem.... is it possible to replace them myself or is this the type of work that calls for a qualified transmission shop?
    Would it be a horrible idea to just try to smear some rtv on the outside of the seams and hope it works? I'd like to get into some autox but if my shit leaks it won't pass tech!
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
  • LJ851
    • 7918
    Are you talking about the oil seals or the paper gaskets that go between the sections of the gearbox housing?
    Lorin
    The M30 is God's engine.
    • Red88
      • Nov 2008
      • 1161
      Paper gaskets that go in between the gearbox housings
      sigpic<< wrecked
      • The Dark Side of Will
        • Jun 2010
        • 2796
        Are there paper gaskets between the housings or is it anaerobic sealant?
        • Red88
          • Nov 2008
          • 1161
          I'm pretty sure I can see paper gaskets in there.
          sigpic<< wrecked
          • the imitator
            • May 2013
            • 1006
            I don't have gaskets between mine, ill double check when I get home.
            Edit: diff isn't at my home . Haha
            Edit 2: haha!! I meant transmission.
            • Red88
              • Nov 2008
              • 1161
              I'm talking transmission. I can't afford to take it in to get refurbed, so I went ahead and cleaned the hell out of the joint of the two cases and slathered a line of rtv on there. Works so far.
              sigpic<< wrecked
