Will a clutch from a 535i (G260/6 trans I believe, may be a /5) fit/work in an M20/G260? I'm did some searching and couldn't find anything on this. I wasn't sure if the 2 different trans' were different to where you couldn't use one of the other, and if it would work with an M20 flywheel.
Any insight on this is a major help. Thanks.
