BMW actually recommends ATF in the transmission. However, I also know of several people using Redline MTL in their transmissions.
Always open the "fill" plug before you loosen the "drain" plug
ATF is only recommended for 260 transmissions with the ATF tag on them.
Otherwise 75w90 or 80w90 gear oil does the job.
BimmerHeads Classic BMW Power Delivered Worldwide
Grover Beach, California BimmerHeads.com
