Hey guys,
So I recently finished my 2.7i build. Got a stage 3 clutch and lightened the flywheel down to 17lbs (single mass)
I bled the clutch system through twice now and am having the same symptom. When my clutch is depressed there is a whirling noise that is pretty loud and annoying. On neutral. Driving slow. You can hear it very clearly. Only time I don't hear it is when the clutch pedal is pressed down or when I'm driving at a good speed but most likely that's only because my exhaust drones it out. What advice can you guys give me. I'm sure whatever this is, isn't going to end good in the long run even though it mechanically drives fine except for the noise.
Thanks Tim
Thanks Tim
