Sup R3v,
My sister and I recently bought a 91is. We're loving it so far but it does have it's small issues.
The problem I am are having currently is that the car tries to fight back when i put it into first gear. It goes into first smoothly, not rough at all, but once I start letting go of the clutch and press down on the gas, the shifter tries to go back into neutral, seems to get stuck halfway, and makes a horrible grinding noise. Sometimes it shoots back into neutral with a loud popping noise.
This use to happen randomly, mostly when the car first started cold, but it is now happening more often. I don't want to start it from second and only make the problem worse but I can't stand the grinding noise that happens randomly. If I stepp down on the clutch fast enough I can catch it and it won't happen.
Was planning on changing the transmission oil soon, hopefully that helps somewhat but I'm starting to worry that I might be a bigger problem.
Another thing I have been noticing is that it feels like I can shift the car without even using the clutch. However I haven't tried to do that yet. But It seems to shift way to easily like if the clutch isn't doing anything. Could it possibly be that?
We have been tackling the small issues but I do not feel very comfortable dealing with the major things because I don't know much yet
So I might take the car to a mechanic. Just wanted to hear what some of you had to say or give me some advice on how I can inspect this myself.
Like always, thank you guys.
