My clutch doesn't seem to work 100% correctly since last year. Sometimes the gears are not engaging smoothly so I decided to reverse bleed my clutch.
I did it the correct way by plugging a oil can to the slave bleeder and pump slowly but no air is coming to the reservoir and the line keeps popping off and spreading fluid everywhere since there's so much pressure in it.
Could my slave be clogged ? I don't understand why oil is not going up.
My pedal is still firm and feels ok but having no oil coming from the slave bleeder is weird.
