This weekend I installed revshift subframe bushings and RTABs. I got the subframe riser ones and installed the differential spacers which accompany the kit. I installed a new CSB also while I had them out bc the old one had a crack in it and produced a mild vibration in 1st gear. Giubo is also new (<10k miles).
Now after getting everything all buttoned up I have a vibration from top of 2nd to bottom 3rd when I give it the beans. At freeway speeds theres no vibration. What could it be? I preloaded the CSB and all the bolts are tight at the tranny and the differential. I maybe, maybe forgot to tighten the collar nut that combines the two driveshaft ends. Would this be it?
I've also done the driveshaft multiple times before so I know the process and I lubed all the joints w silicon spray.
Going to go back under today but wanted R3v's input.
Thanks guys.
Thanks guys.
