Looking to get a longer diff on my e30 m3
  • m3j0n
    • Feb 2006
    • 395
    what are my options if I want to stick with a factory LSD that fits in an e30 m3 and can accept an mcoupe finned diff cover?
    my factory diff is a 4.10 and its way too short with my 95 m3 s50/zf swap. What LSD ratios were offered from the factory that I should consider? Thanks!
  • FredK
    • 14762
    You have a ton of options.
    Any Z3M diff will bolt right up, and get you very close to the gearing of a Z3M. Because the E30 tire diameter is smaller than a Z3M's, the effective ratio will be slightly higher.
    So, a 3.15 or 3.23 from a Z3M will work. An E28 3.25 or 3.46 LSD will also work with the finned diff cover. If you want a nice low diff ratio, you can get a 2.93 from a 325e.
    • m3j0n
      • Feb 2006
      • 395
      is a z3M diff any different from a standard e36 diff, for example one from an e36 m3? Which year z3M had a 3.15 vs 3,23?
      • FredK
        • 14762
        Yes. The Z3M has the same case-style as the E30 (and E28/E24/E23). It is incompatible with the E36 diff.
        The S54 Z3M had a 3.15. The S52 Z3M had a 3.23.
        • m3j0n
          • Feb 2006
          • 395
          ok, cool.. thanks... I don't think Ill be finding a 3.15.. that must be ultra rare.
            • 37833
            A 3.25 ratio is just about perfect for that engine and trans combo.
            Grover Beach, California
            BimmerHeads.com
            • m3j0n
              • Feb 2006
              • 395
              yeah.. trying to find one now... they are either priced high, or sold....:(
              • ajhostetter
                • Apr 2013
                • 1218
                Wanganstyle (on here) builds 3.15 torsens for the E30. I just picked one up. PM him. He knows rear ends and can build pretty much anything.
                2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
                • e30rapidic
                  • 2167
                  I have an S3.25 with my S50/zf, best all around ratio i've tried. S3.46 was great fun but too many rpm's. S2.93 is great for cruising but sucked a bit of the fun out. It is a toy after all.
                  i'm building a 3.15 now, got the gears from an e36
                  '87 325ic, powered by S50.
                  • lukeADE335i
                    • Apr 2013
                    • 1389
                    The 3.25 LSD is common in the e28 535i - that's where I got mine from.
                    My e30: OEM+ with M30B35
                    • m3j0n
                      • Feb 2006
                      • 395
                      Probably more pricey than sourcing a used diff though, right?
                      AWESOME info! Thanks for being the guinea pig!! LOL.
                      cool. thanks.
                      • Wanganstyle
                        • 2828
                        cool. thanks.
                        Much more but new everything is just that
                        If you have a rear end shop local to you that knows BMW units they can just re-configure your original differential from 4,10->3,15. Lots of labor to expense.
                        I always fit the late model E36 gears as they are a updated more efficient design than the earlier e28/34 gears. Some won't care about this; BMW revised gears for efficiency mid 90's and then again late 90's in the e38/39/46
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          For the ZF gearbox, 3.15 is the perfect ratio for street/highway driving with some AutoX and/or track days sprinkled in.
                          Originally posted by kronus
                          • lukeADE335i
                            • Apr 2013
                            • 1389
                            Any idea how much difference to economy would this make? Always interested in making the car better on fuel. :)
                            • Wanganstyle
                              • 2828
                              very difficult to quantify this; a gearing change will be much easier to compare.
                              Fuel data for Average combined Fwy/local driving (prior DD's)
                              1998 M3 3,23->3,46 = decrease 24-25 MPG to 22-23 MPG
                              2003 325i 3,15->3,46 = decrease 25-26 MPG to 23-24 MPG
                              1992 525i 3,23 ->3,15 = increase 23-24 MPG to 24-25 MPG
                              the more modern m54 engine with is double vanos and can bus electronics is much more conservative on fuel on freeway cruising; its 29-30 mpg.
                              Obviously 3200cc vs 2500cc is another issue regarding mpg.
                              Choose the final drive that suits your desired MPG for the kind of driving you enjoy. Stock BMW is always good
