Hi guys,
Working on a 1988 325 and I just wanted to confirm a tip that I read on another forum from someone here.
Turns out my car has an 180mm Selector Rod and I foolishly ordered the 187mm DSSR thinking all e30's were the same. Just wondering if I have this correct....
The selector joint from a 9/94+ e36 is 9mm shorter than the stock 89-8/94 joint. So if I was to combine this with the 189mm DSSR for an e36 325i I should be golden with everything adding back up to 180mm?
Or as an alternative has anyone used the CAE adjustable DSSR?
Thanks in advance!
Thanks in advance!
