So after doing a super hard launch the other day like a chump I've noticed that my clutch pedal is now vibrating when I push it in and release it. It doesn't seem to vibrate when fully pushed in or when its just sitting, its only at about the half way point. Almost like something is unbalanced. It seems to drive just fine and shifts normal, just has a funny vibration. I've looked up the symptoms and it sounds like it may be the throwout bearing or a spring on the clutch disk. Any ideas on how long it can be driven on like this? Would it be grinding up my clutch every time I drive it?
Clutch problems
probably broke a spring in the friction disk , and depending on how broken the pieces are the will eventually come out into the pressure plate (possibly scoring the flywheel) ,or out into bellhousing possibly getting jammed in ring gear, anyway Not Good and hard to tell how long it will last or what damage its doing till removalAngus
88 E30M3 X2
89 325IX
92 R100GS/PD
I agree with both replies above. I would not drive car until you can pull the trans and figure out the cause if your noise.
Sent from my 831C using Tapatalksigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback ThreadComment
Hmmm.... tits. Would http://www.pelicanparts.com/cgi-bin/...-1-223-102-M38 this kit be what I need?
Are clutches are hard DIY job? Never done one before.Comment
