Hey Guys
Let me poke your brains for a sec.
I did the swap about a year ago, I have:
M50TU
ZF 320
M20 clutch Disc
Single Mass FW with spacer
328 Slave and Master
Had m20 TOB now euro 323
When I had the m20 TOB I had to really press the pedal into the carpet to get the clutch to disengage so that I can get into gear smoothly. As time went on it got more and more difficult until it simply wouldn't go into gear anymore. I popped in the 323 tob hoping that the extra length on it would help the situation and it goes into gear now with difficulties.
I also found that if i get my foot behind the pedal and pull up on it before i press down on it, it shifts butter smooth. While it works, it's not supposed to be that way. Any thoughts on what may be causing this? Suggestions?
Does anyone have experience with this motor/trans/clutch combo and what's your setup?
M50TU
ZF 320
M20 clutch Disc
