Clutch Pedal Compatibility Question...
  • chrisca70
    • Sep 2013
    • 239
    My car is a non-airbag E30 02/89. I need to change the clutch pedal assembly (it was messed up by the previous owner with soldering, etc.).
    I was able to source a Clutch Pedal but it is from an airbag E30. Would it fit no problem? Any compatibility issues?
  • chrisca70
    • Sep 2013
    • 239
    Been doing some more searching, my guess is that it won't fit. If anyone has experience with this chime in, otherwise I'm buying the pedal and related parts new from the dealer, not that expensive after all...
      • 37833
      You will need a non-airbag pedal assembly. Any 84 through 89 will work.
      Grover Beach, California
      BimmerHeads.com
      • chrisca70
        • Sep 2013
        • 239
        Thanks for confirming MR 325. I just ordered the whole assembly brand new from a trusted dealer. BTW you have a sweet M-tech car...
