So im getting my e30 lsd rebuilt and the guy tells me that my pinion gear's shaft is all scratched up and so i need new gears. Im heading to the junkyard now to see what I can find. What bmw models differentials have gears that can bolt up directly to an e30 medium case lsd unit?
All you Diff experts out there!
Tags: None
What ratio?2001 silver/Blk 325 cabby. SOLDOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leather -
I was looking for any ratio between 3.25 - 3.73. I actually ended up picking up a 3.91 from a e36 328i, since I didn't have any luck finding anything else...they are both medium case (188mm). Any idea if the internal gears can just swap out into my e30 lsd unit?Comment
^ Fully rebuilding one is the correct way to do it.
Not sure if they will fit. Just make sure you use both the pinion and ring gears from the donor even if it's the same ratio as your original diff.Drive it hard. Maintain it well.
A Topless MemorandumComment
I agree with that being the easiest, I am in the process of getting mine rebuilt, just ran into an unexpected problem with the shaft of the pinon being scratched up which was caused when the lsd gave out on the freeway on my way to work one morning. Also, Why replace the clutch disc???
Yea, the guy I took it to specializes in all differentials and he also recommended using both pinion and ring gears, thats why i figured why not just change the gears out to a different ratio. Unfortunately I couldn't even find any of the ratios I was actually looking for...DAMN you junkyard people! lolComment
What do you mean by "the lsd gave out on the freeway"? do you mean the bearings went bad? I dont' think the scratches on the shaft will make it a bad diff if the gears, seals, torque, and backlash is still good. Post pic of the scratches.I agree with that being the easiest, I am in the process of getting mine rebuilt, just ran into an unexpected problem with the shaft of the pinon being scratched up which was caused when the lsd gave out on the freeway on my way to work one morning. Also, Why replace the clutch disc???
Yea, the guy I took it to specializes in all differentials and he also recommended using both pinion and ring gears, thats why i figured why not just change the gears out to a different ratio. Unfortunately I couldn't even find any of the ratios I was actually looking for...DAMN you junkyard people! lolsigpic
327is
325es
325es
318is
Fiesta ST
E46 M3Comment
I don't think all ratios are swappable, but you should be able to split an open diff and use those as well I believe. Gives you much more choices, nobody buys open diffs so they're cheap.Drive it hard. Maintain it well.
