Hi all,
I'm having a noticeable noise coming from the what sounds like the trans. Sounds similar to rocks tumbling in the bell housing. All the searching I've done, leads me to the "getrag rattle". However, most people who experience this explain that the noise goes away when the clutch is depressed. The noise mine makes does not change if the clutch is depressed or not. It's fairly noticeable at idle and I can faintly hear it while cruising. Also, the noise is effect by rpm. It's also too inconsistent to be a rod knock. Btw, the car is A 88 325i
Thanks in advance!
Thanks in advance!
