My trans has the getrag rattle, and I think the whine in 1,2,3 gear has gotten a little bit louder. The layshaft bearing is probably toast, right? Will the trans eventually blow up leaving me stranded or is the whine just an annoyance?
Is there any trans oil/additive that can quiet it down a little bit for now? (BG or redline shockproof) Im considering a reman or swapping a lower mileage used getrag260 but haven't decided just yet.
Other info: Original 325e g260 with 275k filled with mt90. Prior to refill, looks like PO let it run dry, as shifter and rear seal leaked. After reseal, checked fluid again and it came out like chocolate milk.
Thanks
Thanks
