Transmission mounts ?
  • SmallDave
    • Jan 2015
    • 100
    So it can stick or be a little tough going into 2nd and reverse (reverse hits the side of the plastic on the left) and 5th is almost right in the middle. There is also a slight vibration between 2 and 3k in first and second gear. Very minimal. But from my research it could be worn trans mounts. Visibly they don't see all that contorted, maybe slightly compressed toward the trans. I'll be ordering mounts today unless there are any other suggestions! thanks!
  • turbo55
    • Jul 2014
    • 223
    Sounds like somethings broken or bent with your gear selector to me.
    I'd take it apart for anything obvious.
    Also, check this out: http://www.r3vlimited.com/board/showthread.php?t=215556
    • SmallDave
      • Jan 2015
      • 100
      Thank you!! Could that be the issue of a slight vibration at low speed accelerating too?
      • Boris3
        • Apr 2007
        • 444
        What condition are your motor mounts in?
        Trans mounts can look fine but may be sheared. Sometimes can't tell until take the weight of the tranny off them.
        1990 325: track/racecar
        2003 330xi; project car
        2004 330i zhp: civilized car
        • SmallDave
          • Jan 2015
          • 100
          Good point, I will do that.. motor mounts look fine but I have limited e30 experience, could it be the same deal with those too ?
