Hey folks,
I own a 89 325is. The car had a transmission leak. A private party inspection cited "Rear transmission seals and detent cover." I had this work done at an independent shop. And as a preventive step, i had them install a driveshaft bearing replacement kit and flex disc/gubio replacement kit. Since the work was finished, I have notice a whine that does not go away when engaging the clutch. The whine does go away after driving for 15 mins or so, but returns upon a cold start. Any thoughts? transmission bearing? coupling between drive shaft and transmission? spline nut on the driveshaft? I appreciate your input!
