I have a 1996 e36 328is. Needs clutch. Would like to lose the dual mass.
Realoem sez 240mm clutch disc diameter.
I have a flywheel/clutch out of an 84 733i. Good condition. It should be a 240mm diameter set up.
Not trying to cheap out but...would it be possible to use the e23 flywheel/clutch in the e36?
Stack height differences on the clutch? Ring gear tooth count?
Thoughts? Thanks in advance.
