E30 Center Support Bearing HELP!!
  • R3vunlimited
    • Oct 2014
    • 50
    The rubber on the CSB mount went out recently, so I bought one from Turner Motorsport and have no garage to do this in right now. I was wondering if anyone out there knows if you can just disconnect the drive shaft from the diff and drop the back half of the drive shaft to replace the bearing and mount...
    Any help would be greatly appreciated. Trying to do this as quick and easy as possible. Thank you!
  • E30 331is
    • Sep 2011
    • 1166
    From what I remember, its tapered around the CSB area. So no.
    The best way I have done is undo where the guibo under the shifter, mark the half shafts, undo, slide out, replace CSB, aligned markings, preload the CSB.
    Done!
    • R3vunlimited
      • Oct 2014
      • 50
      Done!
      Dang, yeah I figured I would have to pull the whole thing, but I thought Id see if anyone else did it differently. Thanks for the input!
      • E30 331is
        • Sep 2011
        • 1166
        Leave the diff side alone, just support half the shaft.
        • AndrewBird
          The Mad Scientist
          • 11898
          It's only 3 more bolts to pull the whole thing out. Why would you not?
