I realized I posted this to the DIY section...DUH...sorry.
Anyway, I am about to start work on installing my Z3 1.9 short shifter and rebuild my shift carrier using Garagistic's delrin bushings (doing the rear bushing too). I have read all of the threads and bought the HF "bitch clip tool". Also reviewed the instructions on Garagistic's website. I have my car jacked and muffler is removed (I just finished installing Billy Sports/HRs and am changing to Stromung exhaust).
I understand that I need to jack up the trans and remove the trans cross-brace. Can this job actually be done with the driveshaft and the exhaust (front part/Cat) in place? Is there anything else I need to remove. The PO did the center bearing not too long ago and everything is pretty tight.
Any additional words of wisdom?
Thanks. Swen.
Thanks. Swen.
