Hi.
I got a E30 325i and I hear a clunk-clunk-clunk noise when I let out the clutch mainly at slow speeds going out of reverse and 1st gear.
Also while driving, if on a certain gear, mainly 4th I let off the gas quickly I would hear and feel a clunking/shaking in the drivetrain.
The guibo is good, the clutch doesn't appear to slip. I assume the centre bearing is good as the driveshaft doesn't have too much up/down movement.
Could it be loose gearing in the diff, or clutch/flexplate issue?
Cheers.
Cheers.
