Late model shafts in Early model
  • SamE30e
    • Sep 2007
    • 4319
    Hey,
    I can't seem to find a solid answer. I know the pre 85 build cars have smaller wheel bearing diameters. But will a late model non-abs shaft fit into a early model trailing arm?
    I heard the trailing arm diameter is smaller which I can't find answer about the axle actually fitting?
    ETK says for all 325e's non ABS it's - 33211226333
    And up till 85, it says the trailing arm is a 88mm and after 85 its 91mm. Has anyone used earlier trailing arms with later shafts? I snapped an axle and can't find a early model replacement, but can find plenty of late models. I was actually looking at the 4340 CAtuned axles.
    Thanks,
    Sam.
    1985 325e 2.8 Turbo VEMS
    • 37829
    Yes the later axles will fit the earlier hubs.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • SamE30e
      • Sep 2007
      • 4319
      I ended up getting a late model non-abs shaft and it went right in.
      Now I'm afraid to put my drag radials on lol... I might grab some extra shafts and keep them in the trunk.
