When i depress the clutch, it's nice and quiet, but when i let the clutch out (transmission is in neutral) there's a sound coming from the transmission. Maybe it sounds like a worn out clutch... like the clutch plate is Loose????... but the clutch/pressure plate/flywheel is brand new...
Why is it making this "loose grinding" sound.. i oiled and lubed everything up like i should...is this common??
