My transmission has had 2 instances in the last month where it did not want to shift into reverse. I was driving and trying to back into a spot. I would put it into reverse and nothing would happen.
Both times I tried goign to park then back to reverse. Didn't work. Then nuetral to reverse, still no improvement. If I put it back in drive and circle back, it worked again, both times.
These incidences were 3 weeks apart and I have used reverse plenty of times in between, so it is considered sporadic/intermittent at this point.
What could these symptoms mean? Thanks in advance!
