Hey guys,
I'm almost done with my 5speed swap and engine refresh (pulled whole motor)
and now everything is back in the car.
I bought a new shifter carrier and DSSR and z3 1.9 shifter w/new bushings. However, now that everything is installed, the shifter sits in neutral in-line with 1-2, instead of the normal 3-4. The motor is bolted down to condor solid mounts, and the trans mounts are 90A poly.
Any suggestions?
Any suggestions?
