Plenty of people do this on z3's to mount double ear units. But honestly in a e30 the single ear unit is ok untill 400rwhp or so if you have a z3m cover; it's stronger.
Hi guys, can someone confirm if the e36 188mm diff cover will bolt on to the e30 188mm diff housing? does the speed sensor line up correctly?
Thanks
The E36 uses a smaller diameter VSS wheel. Such a conversion *should* use the E36 wheel, sensor and cover.
I have a 3.64 viscous diff from a 325iX with E36 rear cover. The viscous diff uses a different diameter to mount the trigger wheel than the conventional diffs, so only the viscous diff wheel will fit. I had to cut the teeth down to fit the cover and sensor.
