So my car developed a grind/scrape noise while coasting. For example, accelerating through 3rd gear, get up to 3000rpm and then get off the gas and it scrapes until you go back on the throttle or press in the clutch. It is RPM dependant.
We thought it was an input shaft bearing, so we swapped trans on it. It got a new clutch kit and rear main seal, put it all back together and it is still making the noise.
After lifting it back up and looking at it, we noticed the front diff mounting bolts were missing. Could this be whats causing the noise? and what could the driveshaft/halfshafts be rubbing on? so i know to check for damage.
Thanks,
Nick
Thanks,
Nick
