Which bmws had 3.25 lsd as diff for 325e swap
  • cirrusblue
    • Oct 2014
    • 433
    Hello. Like a lot of folks I'm trying to source a 3.25lsd for my chipped 87 eta. The yards I've been calling haven't been super helpful because I don't know the exact models from Bmw and the years that may have had a 3.25 lsd. Can you guys give me any models and years I can use when I'm looking? I know some 535is had them etc. Thank you v much.
    Sent from my XT1528 using Tapatalk
  • cirrusblue
    • Oct 2014
    • 433
    The current diff is a 2.83lsd.
    • cirrusblue
      • Oct 2014
      • 433
      2.93. Sry
      • cirrusblue
        • Oct 2014
        • 433
        Differential Ratios
        We have the listings from 1987 thru 1994 but none of the rest. If you know of a resource for the other years please let us know.
        Explanations: (M)=manual transmission
        (A)=automatic transmission
        E30 1987 1988 1989 1990 1991 1992 1993 1994
        318i/is (M42) * * * * 4.10 (M) * * *
        318ic (M42) * * * * 4.27 (M) 4.27 (M) * *
        325 2.93 2.93 * * * * * *
        325e/es 2.93 * * * * * * *
        325i/is/ic 3.73 3.73 3.73 (M) 3.73 (M) 3.73 (M) 3.73 (M) 3.73 (M) *
        4.10 (A) 4.10 (A) 4.10 (A) 4.10 (A) * *
        325ix * 3.91 3.91 (M) 3.91 (M) 3.91 (M) * * *
        M3 * 4.10 (M) 4.10 (M) 4.10 (M) 4.10 (M) * * *
        E36 1987 1988 1989 1990 1991 1992 1993 1994
        325i/is * * * * * 3.15 (M) 3.15 (M)
        3.19 (A) 3.19 (A)
        318i/is * * * * * 3.45 (M) 3.45 (M)
        4.45 (A)
        325ic * * * * * * * 3.15 (M)
        3.64 (A)
        E28 1987 1988 1989 1990 1991 1992 1993 1994
        528e 2.93 3.25 (M) * * * * * *
        535i/is 3.25 3.25 * * * * * *
        M5 * 3.91 (M) * * * * * *
        E34 1987 1988 1989 1990 1991 1992 1993 1994
        525i (M20) * * 3.73 (M) 3.75 (M) * * * *
        4.10 (A) 4.10 (A) * * * *
        525i (M50) * * * * 3.23 (M) 3.23 (M) 3.23 (M) *
        525it * * * * * * 4.10 (A) *
        530i * * * * * * * 3.07 (M)
        3.15 (A)
        530it * * * * * * * 3.23 (A)
        535i * * 3.46 (M) 3.46 (M) 3.46 (M) 3.46 (M) 3.46 (M) *
        3.91 (A) 3.91 (A) 4.27 (A) 4.27 (A) 4.27 (A)
        540i * * * * * * * 2.93 (A)
        M5 * * * * 3.91 (M) 3.73 (M) 3.73 (M) *
        E24 1987 1988 1989 1990 1991 1992 1993 1994
        635csi, L6 3.64 (M) 3.64 (M) * * * * * *
        3.91 (A) 3.91 (A) * * * * * *
        M6 3.91 (M) 3.91 (M) * * * * * *
        E23 1987 1988 1989 1990 1991 1992 1993 1994
        735, L7 3.46 * * * * * * *
        E32 1987 1988 1989 1990 1991 1992 1993 1994
        735i/il * 3.64 3.64 (M) * * * * *
        740i/il * * * * * * * 2.93 (A)
        750i/il * 3.15 (A) 3.15 (A) 3.15 (A) 3.64 (A) 3.64 (A) 3.64 (A) *
        E31 1987 1988 1989 1990 1991 1992 1993 1994
        850 * * * * 2.65 (M) 2.65 (M) 2.65 (M) *
        • cirrusblue
          • Oct 2014
          • 433
          I found a cool chart...
          here
          • kronus
            • Apr 2008
            • 13032
            E28s are 3.25, as are E36 M3's. You'll need to swap the rear cover and output flanges for both.
            cars beep boop
            • mr.vang
              • 4371
              You can get the gears off ebay and swap in your lsd unit. Also, you'll learn a thing or two while you put together the diff.
              • e30rapidic
                • 2167
                True but are you sure the e36 M3 diff isn't a 3.23?
                It will be better/cheaper for you to find a complete diff as the carrier size in the 2.93 is different than what you need to swap gears.
                '87 325ic, powered by S50.
                • cirrusblue
                  • Oct 2014
                  • 433
                  I'd love a complete diff. The issue is I can't find one. I'm calling all over.
