I just need some advice on where I should start trying to fix it? I need it up very quickly please and thank you
1987 325 wont shift into anygear
Tags: None
Is it an auto or manual?88 325i Cabrio
04 Neon SRT-4
Originally posted by MrBurgundyIf R3v was a dude, it would pick up a tinder date naked, with a raging boner, drunk, in an e30 with a shitty interior, a missing sunroof panel, explaining how its a classic while staring at the tinder date's tits. -
Can you shift it with the engine off? If so, your problem is the clutch isn't releasing. Bleed the clutch hydraulics and see if it helps, if not, you have a problem with the throwout bearing or pressure plate. Tranny will need to come out for access to the clutch.Comment
