trans swap
  • jrhslick
    • Apr 2016
    • 10
    trans swap
    For anyone who has done this, what is the cost of auto to manual granny swap?
  • Julien
    • 7472
    1-2k if you do the labor yourself depending on price of the parts you get and the bling factor (short shift kit, flywheel and clutch). Brad in greenville, sc might have swap kit.
    Build Threads:
    • getouth
      • Jan 2010
      • 3343
      ^ correct. I'm doing one right now I got the swap hard parts quite cheap, Getrag 260+ pedal box+ drive shaft+ cross bar+statrer etc $375. I lightened the flywheel $240 (13lbs) and bought all associated components new clutch kit, guibo, fork, spring, pivot, seals, mounts, center support etc $480, all new short shift kit and associated parts $250.
      FEEDBACK:
      http://www.r3vlimited.com/board/showthread.php?t=316212
      BMWCCA #398608
      IG @yagayo38
      "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
