Halfshaft question
  • Lirker
    • Apr 2015
    • 60
    Halfshaft question
    Hello. I have a 1985 325E, with full stock rear suspension.
    I'm swapping in a 4.10 differential. My question is if I buy 325E half shafts will everything bolt right up? thanks
    Lirker
    '90 325i
    85' 325IE
  • MR E30 325is
    • Dec 2008
    • 3300
    You will be fine as long as the differential is still housed in the OEM sized housing (medium case).
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • flyboyx
      • 8371
      the axles are for all practical purposes the same. even a small case diff would work fine if that is what you chose to use.
      Gigitty Gigitty!!!!
