Are anti-lock brake axles interchangeable with non anti-lock brakes
  • tomstin
    • Mar 2015
    • 570
    I'm looking to replace my axles and it seems most of the places stock anti-lock brake axles. Will they fit in my non anti-lock brake car?
    I installed new boots and the bearing races looked pretty worn also seemed to have a lot of slop.
    2004 525i Manual - 1985 325E Coupe Manual
  • Bearmw
    • 1323
    I'm not 100% sure but I think the only difference is the ABS axles have a reluctor ring pressed on. The ring can be removed if not wanted with a chisel.
    • hot carl
      • Jul 2015
      • 24
      what year do you have?
      the axles on 84-86 cars are different than the ones on 87+.
      early cars didn't have an abs option.
      they have a different flange on the output side.
      early and late axles aren't interchangeable.
      if you have a later car, you can just knock the ring off.
      or leave it on. i think it doesn't make a difference?
      if you have an early car, good luck finding decent axles. i've got an 85 and am looking for some. proving to be difficult.
