Hey I'm looking into doing a manual swap. I not sure how much a manual swap will cost. I'm assuming somewhere from 400-1000$. Which parts will be the most expensive? How much is a good condition G260 tranny?
Parts:
transmission
trans cross member
trans mounted exhaust hanger
clutch disk, pressure plate, throwout bearing w/fork and spring, pivot pin
flywheel
driveshaft w/ CSB and guibo and hardware
shifter assembly including bracket that bolts to body at the back of the assembly, the boot, and the sound deadening shit below it
master and slave cylinder, hoses, hard lines with body clip for trans tunnel
pedal box
Parts:
transmission
trans cross member
flywheel
pedal box
