Bought 5 speed swap parts from someone local on craigslist.
This is what was included:
Getrag 260 w/ clutch fork
Driveshaft
Pedal Assembly
Clutch lines/ master / slave cyl
brake booster w/ resevoir
shifter assembly/boot
trans crossmember
clutch (will replace w/ new)
and flywheel (will resurface)
I'm looking for a DIY that will help me locate/replace all of the seals on the trans... After searching, I haven't found anything. Any thoughts?
What are some other parts I need that will be new?
So far on my list, I have:
Throw out bearing
pilot bearings
Shifter bushing & shims
Center support bearing
Am I missing anything else?
EDIT: Also want to mention -- the trans is from an 86 eta, going into an 88 super eta -- anything I should consider?
Driveshaft
Pedal Assembly
trans crossmember
Throw out bearing
pilot bearings
