IMPORTANT tranny compatibility
  • NC325iC
    • Mar 2004
    • 6565
    ok, is the 260 from an 87 e compatibility with an 89 i.
    i think i know that they will bolt up right but what do i do about the reverse sensor and such
  • AdamF 88iS
    • 2051
    You can use the 87 in the 89, but not the other way around.
    Reverse sensor is the same. Plug the holes for the 2 flywheel sensors, the 89 doesnt use them.
    Output flanges may be different, but are swap-able.
    One of the smaller bolts in the lower left of the bellhousing may be too short or too long, but swap-able as well.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • NC325iC
      • Mar 2004
      • 6565
      output flanges like output to driveshaft? what goes into changing them?
      and i have all the bolts from my current tranny, and will be keeping them as my tranny is pretty toast (well just needs new bearings really)
      • NC325iC
        • Mar 2004
        • 6565
        bump
        • DEV0 E30
          • Oct 2004
          • 8882
          I'm doing the same exact thing within a few weeks. Some stuff may not line up on the bell housing as said, but it works. AFAIK. What is the production date on the E. I know some changes happened in 87. Not sure if anything changed around the tranny.
          James Crivellone told me:
          If you use all the E parts then you do not need anything. If you want to get some better performance out of the thing then I recommend the following.
          I single mass flywheel machined down to around 13lb
          I Clutch
          I Pressure Plate
          *533I throwout bearing *Part #21 51 1 204 525*
          *Otherwise the clutch will not grab as hard if you use an I flywheel/I throwout bearing with an ETA transmission. (the bellhouse is a tad deeper)
          • NC325iC
            • Mar 2004
            • 6565
            can anyone else give me any insight on this?
            • NC325iC
              • Mar 2004
              • 6565
              prod date on the e is april 87
              prod date on my car is 01/89
              • NC325iC
                • Mar 2004
                • 6565
                i think i found all the info i need
