m3 4.10 lsd vs 325iC 4.10 lsd ???
  • MIKe30
    • Sep 2006
    • 2334
    i did some searching but couldnt find the answer, perhaps i'm just bad at searching...
    but is there any difference between an e30 m3 4.10 lsd and any other 4.10 lsd from e30's (i.e. convertable, 318?, etc..)
    please, shed some light!!!
  • Axxe
    • Aug 2004
    • 3355
    As long as it's 6 cylinder, it's larger case and good. 318's have small case LSD's, which are useless.
    BTW, automatic iS's came with 4.10 LSD's from '88 and up.
    Keep it slideways!!
    • MIKe30
      • Sep 2006
      • 2334
      m3 is 4 cylinder, is that the only exception? oh, and what about auto verts?
      • CarsSuck
        • Oct 2005
        • 968
        Yes, the m3 is the exception. It needed the beefier diff to handle the extra power.
        --Will
        • MIKe30
          • Sep 2006
          • 2334
          thanks for the info
          • Rocla
            • 922
            Euro spec 320i, 323i and 324d had small case diff's, whilw 324td has big.
            Current:
            BMW 320i 2d 2.0 m20 -88
            BMW 325i Cabriolet 2.5 m50 -88
            BMW 316i touring 1.6 m40 -90
            BMW 320i 4d 2,2 m54 -01
            • X2theZ3
              • Mar 2004
              • 932
              the 4.10lsd from the auto 325i (including verts) is the exact same diff (same part#'s) as the e30 m3 diff.
