Hi R3vlimited. I recently swapped my stock 1991 E30 325i shifter for the Z3 1.9 Short Shifter. I am aware the selector rod needs to be bent so it fits properly. I can still drive it no problem but it is hitting the vibration damper slightly.
My question is: Can I buy the DSSR selector rod from Garagistic and not worry about bending it? I know it will fit, but if I have to bend it, I might as well bend the stock one.
The selector rod on Garagistic is called "E30 325i 187mm DSSR Selector Rod"
