OK so I have a 91 318is. I have swapped a M50 in to it a few years back. When I did the swap I kept the G240 transmission and also used the clutch for the 4 cylinder that was already in the car. I now have the opportunity to get a brand new clutch kit with flywheel for a 98 528i with a M52. My understanding is this clutch set up is larger then what I am using. So what I am trying to figure out is will this clutch and flywheel bolt in to my car and work with no problems or do I need to swap any parts like a starter or maybe a transmission. Any one have experience with this. Thanks.
