No reverse or 5th after new shifter
  • DirtyDan13
    • Dec 2017
    • 8
    So I initially had a sheet metal shift console that I converted to the aluminum type carrier. Now, after installing a short shifter I can not shift into reverse, 3rd is questionable and there is no 5th gear. I also still have the balancer on the transmission, but it’s the type that’s attached to the transmission and not the drive shaft. Is it possible the shift rod is too long? Also how would I go about removing that type of balancer?
  • AndrewBird
    The Mad Scientist
    • 11898
    If you have a bent style shift lever, perhaps you installed it backwards?
    • george graves
      • 19997
      Sounds like a friend and some sturdy jack stands are in your future. But Andrew hit a good point.
      Originally posted by Matt-B
      • Steve Corbett
        • Jul 2012
        • 449
        I could use the sheet metal shifter plate if you don't need it.
        Steve Corbett
        1983 528E Scrapped
        1983 528E Sold
        1984 745I
        1984 325E - Sold
        1989 325I Bronzit-Sold
        1989 325I Zinno
        1988 635CSI
