I've read from other posts that the airbag pedal box is the exact same for the manual and auto. So theoretically the pedals from the non airbag pedal box can be transferred over. This seems to work except I don't have enough clearance between the wiring loom next to the clutch to manage to feed the longer bolt through the pedal box. The clutch pedal already rubs pretty aggressively on it and not sure what to do. The wiring under the dash seems to have been messed with from one of the previous owners. If anyone has a photo of how the dash should look for a E30 with an airbag underneath that would be great. Has anyone had any issues with this and if so how to solve it?
