Diff swap... gotchas? what to replace? loctite?
  • mike.bmw
    • Dec 2015
    • 1768
    I'll be swapping diffs in my 318is in the coming weeks (small case 4.10 open to small case 4.10 LSD). I've already installed a stud kit in the replacement diff to make the job go easier. I plan to change the oil with Redline 75W90 prior to installing the replacement diff in the car. The bushing seems to be in decent condition.
    I've read a few DIYs on this, but I have questions:
    - Where should I apply loctite? (Already installed on the stud kit per manufacturer's specification)
    - Should I plan to replace any hardware during the swap? If so, what?
    - Do I need to remove the exhaust to have clearance for the diff/carrier bolts?
    Aside from simply unbolting the old one and installing the new one, anything I'm missing aside from what I've already done?
    Thanks,
    Mike
  • agent
    Vice Grand Pubaa
    • 7960
    Red Loctite on the half shaft bolts where they attach to the output flanges of the diff.
    Originally posted by kronus
    • Bearmw
      • 1323
      FWIW I have always used "blue" loctite on the half shaft bolts and they have never loosened (making sure everything was clean of course).
