Hey guys first post here! Just bought a 88 325i auto convertible for $1100 and had the transmission not want to select any gear once it got hot in traffic, got it towed home. Since then I've changed the fluid/filter and cleaned the pan. I used dextron 4 fluid according to other fourms. It hasn't missed any gears or slip anymore but seems to shift very early around 2000rpm even under full throttle while in D. I've been using the manual selector to pass and get going if i need too and shifts fairly hard/quick. Is there any way to change the shift points to shift later while in D via a valve or switch? Also I've put about 3.5 quarts of fluid in for it to show correctly on the dipstick. Any help would be appreciated!
JP
Sent from my SM-G955U using Tapatalk
JP
