Need a link on how to replace my Slave Cylinder ASAP, Please!!!
Tags: None -
Wicked easy, crawl underneth. On the transmission bellhousing(big front part) you should see a hydraulic line going to a small black "thing". Thats the slave cylinder. Just take a 10mm wrench and take the line off, and I want to say the nuts or bolts holding the cylinder on are either 12 or 13mm, and remove. Slave cylinder slided out. Take new one, and simply insert and tighten down, then reconnect line.
If you need a new line, keep in mind you can just use regular brake line, rather than spending lots on a new hose. They are the same thing. Just bring whatever is left of the old one to the autoparts store and they will match it up.01 325Ci
87 325iS w/ M30B35 swap
