sorry....noob at this lol. anyhow, saw an add on the forum for an E30 325is with a blown head gasket.... car seems to overheat within 15mins or so from what the guy said. question is, how much green paper will that cost to get fixed? thanks for the help guys!
blown head gasket issue
Tags: None
How much green depends on how much damage and who does the work. Damage can range from just a bad gasket through a cracked head that must be replaced to engine damage from coolant displacing oil. If the oil is clean (no milky emulsion) the picture is a bit brighter, but the full extend of the cost won't be known until the head is off.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Chances are is it's over heated even once, it's cracked. i heads are very touchy about heat. Around $500-600.00 for a rebuilt head properly done.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
"I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
"If you've got a business, you didn't build that. Somebody else made that happen" Barack ObamaComment
