replaceing clutch. few questions
  • mitch500
    • Jan 2006
    • 1092
    first of all ive got a non- vanos m50, i removed the transmisson today noticing that there was little ball bearings every where in the bell housing. whats the bearing called that slides over the shaft coming out of the tranny.? 2nd question im getting my fly wheel resurfaced tomorrow, and i wanted to know if i get it lightend how many mills should i get shaved off. if i do this will i need to buy shorter fly wheel bolts?
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
  • mitch500
    • Jan 2006
    • 1092
    bump
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1991 Jeep XJ I6 4.0
    • FredK
      • 14764
      1) The bearing that rides over the transmission input shaft is called the throwout bearing
      2) No, you won't need shorter flywheel bolts. They are only shaving the friction surface. However, you should get new bolts. I think they might be stretch bolts. I dunno how many mils to shave off.
      • Mike325
        • Mar 2006
        • 3685
        Your info says you have a 325. So you have an eta I assume? That car came with a dual mass flywheel. I think you need/I would reccomened getting a single mass flywheel off of the e36 or an e30 I engined car.
        Originally posted by Kershaw
        • mitch500
          • Jan 2006
          • 1092
          yes i have a 87 eta, and a 92 525i which im replacing the clutch.
          1987 e30 325 eta
          1983 e28 533
          2001 x5 4.4l
          1991 Jeep XJ I6 4.0
